downpipe question
zap45
which downpipe can i use when i go turbo a civic or for an h23? my chassis is eg with a h23/f22b dohc swap
thanks
thanks
depends on what turbo you have. at this point(assuming you dont have the boost setup yet), i guess ANY d/p will work.......lol
ok what about the length is the prelude turbo d/p longer then the civic turbo downpipe?
or are the same. the turbo i was looking at of course have a 5 bolt
it depends on your manifold more than anything. consult the mfg'er of your mani, and go from there.
If you can weld, or know someone who can making your own is the best bet. That way your wastgate routing and o2 sensor placement is all up to you. There are a lot of places on the web where you can buy random mandrel bends. With your displacement I wouldn’t go under 3" pipe, and stay away from the crush bent stuff.
