dpfi mpfi swap.. help!!!
Discussion in 'HYBRID -> ED-EF / DA' started by spider, Aug 2, 2006.
  1. spider
    spider Junior Member
    Hi! I'm doing a dpfi mpfi swap and i'm having problems, i don't know if it because of the distributor or the ecu, wire connections are all ok for sure, i've checked it a lot of times, does anyone know if the this swap works with the d16z2 distributor and pm7 ecu? i was told t only works with pm6 ecu and i don't have any. the ecu and distributor were bought apart, they are form diferent cars. the spark doesn't get to the spark plug, i've unplugged it.. can anyone help???
    please...
    thanks
    joao
  2. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    Just get the right Distributor for the Engine.
  3. roninallout79
    roninallout79 Plan B
    GER friggin MANY
    The motor and dizzy have to match, The dpfi dizzy uses a 5 wire cannon plug the MPFI dizzy uses a 7 wire cannon plug as long as the PM7 came off a car that had MPFI it should work.
  4. spider
    digging out a post with over 2 years.. if i hadn't worked that problem with that swap already i was fu****... :D
    but hey, thanks anyway! ;)
  5. roninallout79
    GER friggin MANY
    my bad I never payed attention to the date
  6. spider
    no prob! :)
    thanks!
