dpfi~mpfi...=(
Discussion in 'Civic and CRX - EF' started by HondaElite, Sep 3, 2008.
  1. HondaElite
    HondaElite senior member
    fall river.mass
    ok i knoe i knoe its been over a thousand times but i never got the straight answer..can i use a harness and ecu from an si and be all set or will i still need to cut shit???and i would obvs change the i/m and use stock a6 injecters...i knoe you guys are prob tired of talkin about this but can some one jus please let me knoe if this idea works..thanks
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    Yes you are right, it's been covered a MILLION fucking times and the answer is NO. The shock tower plugs on mpfi harnesses are different sizes than dpfi harnesses.
