Have you checked to see for sure if you have a ground pulse to the injectors? As I read back you say that you have spark and the mechanical timing is correct so I am assuming that you have good compression. Have you tested your fuel pressure and flow? It sounds like either a weak fuel pump, restricted filter, or injector problem. Do you have access to a fuel pressure gauge?
