dpfi to mpfi parts check list help
Discussion in 'HYBRID -> ED-EF / DA' started by CRX-YEM, Jan 28, 2009.
  1. CRX-YEM
    Wallingford, CT
    ok, since my TPS on the dpfi is failing I figured why buy a new one when I have almost all the bits to update the intake.
    I think I have all the parts.
    I'm trying to figure out why the mpfi manifold I have looks different than most of the pics I've seen from a google search.
    So I have
    P28, (chipped need a base map for a PM6)
    Resistor box
    Intake w/ TB
    Injectors
    fuel rail with fuel line and banjo fitting
    Distributor
    A wiring harness (might need some other connectors for the injectors etc, as the harness has been butchered)
    MSD ingnition coil, cap & rotor. (would need an MSD 6 or MSD 7)
    I would need an intake manifold gasket, probably replace the PCV, and TB gasket.
    Also it looks like a sensor is missing. Can anyone help identify this intake ?
    Casting markings on intake
    underside of intake
    Thanks in advance
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    that intake manifold appears to be from 92-95 Civic D16Z6 and is missing the MAP sensor on the throttle body - the injectors in it should be OBD1, in which case you wouldn't need the injector resistor box
  3. CRX-YEM
    Wallingford, CT
    ok, looks like I need a map sensor, or is it possible to use the one on my D15B2?? same part number comes back from autozone so I assume they use the same map sensor
  4. jlicrx
    Colorado Springs
    they are not the same - from Autozone, i get #SU4081 for the D15B2 and #SU4022 for the D16Z6
  5. D16SiHatch
    D16SiHatch New Member
    the part numbers are different because your stock map is firewall mounted. you can use that one, but you would have to plug up the hole in the tb somehow.
  6. CRX-YEM
    Wallingford, CT
    I'd like to use my maps sensor if possible as a new one is ~ $250ish
  7. D16SiHatch
  8. CRX-YEM
    Wallingford, CT
    ebay slipped my mind.
    thanks for the link
  9. phunky.buddha
    Dallas / Fort Worth, TX
    I think you have everything. Sell the MSD setup to make some cash back?
  10. CRX-YEM
    Wallingford, CT
    If I sell the MSD setup it's pure profit it was given to me.
  11. lilsicsol
    lilsicsol i lOve my Ef sedaN..
    brooklyn...
  12. phunky.buddha
    Buy a cam with the cash. :)
  13. CRX-YEM
    Wallingford, CT
    I wasn't sure about this but can I use my current TB that's on the D15B2, vs the one that's on the mpfi intake??
  14. austin20110
    austin20110 New Member
    Northern Va
    they should match up i do belive
  15. Justin91civic
    Justin91civic New Member
    Nashville, Tn
    No tb on d15b2 is wrong for that one you need a mpfi tb because the boltpatterns and sensor locations are all different.
