I have a 91 CRX DX, which I am going to convert to MPFI.
Parts list: (I think I have everything I need)
P28, Chipped
Z6 intake w/ TB
Injectors OBD1 (I think I also have some OBD0's as well)
Z6 Distributor
Resistor Box
Misc connectors
So my question is what base map do I burn, my first assumption is a PM6 base map to be used in the P28 as I'm not going to using vtec. Someone on pgmfi.org has suggested to start with a P06 base map, and to use a OBD0 to OBD1 harness which I don't see the need for as the wiring can be done without it. Is there a better base map to use, and is there any rule of thumb or general modified base maps that wold be better for this conversion??
Thanks in advance
Dennis
P28, Chipped
Z6 intake w/ TB
Z6 Distributor
Resistor Box
Misc connectors
Thanks in advance
Dennis
