dpfi to mpfi
I'm doing a DPFI to a MPFI D15B2 to D15B7 in my 89 civic hatch dx, the motor i put in is a 92-96 honda civic motor d15b7 can i pull the wire from the firewall and follow them into the car and pull them out and put the 92-96 civic wires and run the 92-96 civic ecu??? will it be a plug in play or does half of those wires go to the fuse box?? help asap.
if not my friend was telling me to grab an entire wire harness to the entire car brake lights to headlights and grab the fuse box's and everything off the 92-96 civic will this work also?
There are sooo many write-ups on this, Google it and I guarantee the first two pages will give you all the info you need.
