Drag Turbo Kit On The Way
Discussion in 'Forced Induction' started by 831civic, Jan 10, 2003.
Install right away or wait for internals?
  1. Do it now!!!!
    100.0%
  2. wait 'till I build my blo
    0 vote(s)
    0.0%
  1. 831civic
    831civic Member
    I just bought a Drag turbo kit for my H22 powered hatchback. I can't wait to get it. I just don't know whether to slap it on right away or just wait until I get my pistons, rods, sleeves and valvetrain. If I can run my car on stock boost for right now (which is about 7psi) then I think i'll slap the turbo kit on right away but if the risk of fu**ing up my engine is too high, well then I'll have to wait :angry:
    What do you guys think
  2. pissedoffsol
    if you have fuel management- go for it. if not, dont boost it on either not or fully built.
  3. 831civic
    831civic Member
    My whole fuel system is getting upgraded so I will have that. I'm also ordering the aem ems + a wide band O2 sensor. I'm not sure on what size injectors to go with. I'm thinking 66 pound injectors.
  4. pissedoffsol
    lbs are for domestics - go by CC's :)
    550's should be good
    i wouldn't run the turbo until you get the aem, but thats me.
    and owning a wideband is kinda useless unless you own a dyno as well
  5. pissedoffsol
    dude- i wasn't cock blocking you. chill out. i gave my opinion. i wouldn't run 1 psi of boost on any of my motors with out proper fuel management.
    i'd take a hondata over rods, pistons, OR injectors. have all is security, but IMO, fuel management is a necessity
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I think he meant the wideband o2 is useless without a dyno,not running a turbo or EMS.
  7. cws13
    cws13 Senior Member
    Athens,GA
    The new AEM system has a capability to feed you specific A/F ratios and tune your fuel map for you by crossreferencing itself if you have a wideband O2 sensor. Since the Drag kit usually comes with an intercooler and injectors you should be fine to run that 7 psi. With the AEM you'll be good to go. Buyer beware, this thing is not as easy to tune as you may think--even with all of the claims. Also, it's an H22--it won't take much more than a bolt on kit will give it without needing internals. In order to fit all that under the hood (if you havent already) get a slim line fan and install it on the front of your radiator where your A/C condenser went so the turbo will clear the radiator and the new fan should move more air. You will need that dyno to tune the AEM outside of a raw fuel map.;)
  8. 831civic
    831civic Member
    Maybe I got a little too aggressive there, sorry about that pissedoffsol.
  9. pissedoffsol
    its cool- just know that we are all here to learn... not to criticize.
    i don't know everything- nor would i claim to. im sure theres somethings you know that i don't and vice versa
