Driveline Question I need your Experiences
cceinc
When I deacclerate there is a noise and vibration comming from the driver side wheel. I have a ef with a b18c1 the left side axle seems to be ok. The vibration is not a side to side like a broken axle. It is more of a pounding. Has anyone experienced this before?
Are you using DA axles?
Just slap a new axle in there and see if it works. They are so cheap, you'd might as well change it out before something bad happens BECAUSE of the bad axle... ya know?
Shoot, first things first, check the torque on the wheels, and make sure the axle nut is on securely, etc, THEN do the axle swap.
