drivers side axle binding??? help
DVJr84
H22A4drCivic
Okay so i changed the motor mounts and axles and im still getting an axle bind. Although its less than before it still does it on right corners and when i hit dips. What could be causing this??? Differential? I was told that since my speedo doesnt work that could mean that my diff was bad becuase the vss gear runs off of the diff. Im not sure I just want this grinding to go away. Somebody please help
Axle too long? You stated in another thread that you have an H22, but you don't tell what your setup is here.
well i think calesta is right im thinking both axles are to long. when i took the axles out i was able to expand them about 1 to 2 inches on both sides. Im believing that has to be the problem because they're crammed up. Im sending these axles back and telling them to shorten them. What do u guys think could this be the answer to my problem???
