Droping in a ZC, need help
Discussion in 'HYBRID -> ED-EF / DA' started by d16a6civichatch, Jan 14, 2009.
  1. d16a6civichatch
    d16a6civichatch New Member
    i am going to put a doch zc motor in my car and i already have my wire harness set for MPFI.but want to make sure i dont have to mess with the harness any more.... can any one give me a good web site that helps with puting in a ZC motor.? thanks
  2. Fernpatch
    Fernpatch Member
    Bellingham,WA
    If you have your wiring harness set for mpfi already than the only change you will need to make is at the distributor. The sohc mpfi harness has a single round plug at the distributor and the dohc has a rectangular one at the dizzy and than a 2 wire over at the cam sensor. You can use the stock dx dizzy connector and than run the extra 2 wires from the ecu to the cam sensor on the exhaust cam. I don't have the link that I used to do my zc swap but check around this site or at www.thezcr.com Good luck
  3. D16SiHatch
    D16SiHatch New Member
