dropped engine in, and hood wont close...
Discussion in 'HYBRID -> EG-EK / DC' started by arroshiz, Oct 29, 2004.
  1. arroshiz
    arroshiz Senior Member
    i finally got my mounts and dropped my b17 in my 92 vx hatchback, and everything is right and nothing is in the way of the hood closing, but it wont close all the way unless i slam down on it really hard, i looked under it and it clears good, the hood acts like its gettin stopped by something but there is nothin there, anybody else had this problem?
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    did you take it off?
  3. tjr5150
    tjr5150 Junior Member
    if you did then you might have to re alighn it
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Look for a nut or bolt under the hinges. Or like they said if you removed it, it mmay need to be lined up right. Also if during the course of installing the motor you hit the latch it could have mis-aligned that also.
  5. mrnice1058
    mrnice1058 Senior Member
    Pa
    did you take the hood off when you did your swap? i did and when i put it back on it didn't close and i checked my alignment and it was off i put it back in alignment and it closes good
  6. arroshiz
    yeah i had just put the hood back on to see if it would close right, thats probably what it is, it looked pretty straight tho, i already checked for loose nuts or screws under the hinges, thanks i'll try realigning it
