Dropping In B16a Into 91 Integra. Need Mount Kit?
Discussion in 'HYBRID -> EG-EK / DC' started by Akirazian, Feb 20, 2003.
  1. Akirazian
    Akirazian Banned
    Hey since I'm planning on dropping the motor into my 91 LS Integra do I need any mounts? I Am planning on using the B16a1 cable tranny. What else do i need? Is it simply plug and play? VTEC WIRES?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    You will need to add the wires for VTEC and the knock sensor, but you do not need a mount kit. The B16 cable tranny will work fine. Are you sure this is the swap you want? The B16 is great in a Civic, but kinda torqueless for a heavier car like the Integra. I know the DA came with a B16 for 3 years, blah blah blah. There is a reason it only lasted 3 years and the B18C(1) lasted 7...
    Just make sure you know what you are getting before you buy. Good luck.
  3. mellowboy
    mellowboy Senior Member
    ChicagoLand, ILLINOIS
    Yeh i would just go gsr motor. You need that torque to get that heavy body movin :spin:
  4. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    LS/t yO! Boost owns n/a for getting fast cheaply. Well relatively anyways
  5. Akirazian
    Akirazian Banned
  6. lsvtec
    All of these three are better options than the B16 in that chassis.
  7. brc80
    brc80 Senior Member
    Southern California
    Ive done the b16 swap in my 90 integra, if your looking to go cheap(meaning no turbo) id ssay go for the b16 for a daily driver its plenty fast enough, plus with I/H/E and some cams you will happy.
  8. sillyme540i
    sillyme540i Junior Member
    just use the vtec head!!
  9. cbrnascar0329
    cbrnascar0329 Banned
    :withstupid:
  10. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    There's more to a ls/vtec than throwing on a vtec head.
