DSM Injector questions
Discussion in 'ECU's, Electronics, and Tuning' started by IntegraB18LS, Mar 25, 2004.
  1. IntegraB18LS
    IntegraB18LS Junior Member
    I recently picked up a set of blue top 450cc DSM injectors because I belive i have a clogged one on my turbocharged b18. I purchessed 4 10 ohm 10 watt resistors and i got older civic injector clips. anyways after talking to people I was told my car would not be able to idle and it would run real bad all the time until its under boost. I am just using a 255 fuel pump and vortec 12:1 fmu, i do not have a s-vafc or anything. any input?
    Kyle
  2. pissedoffsol
    they are right. you are going to flood like hell from idle till redline. WAY too rich.
    pick up an afc, or put the stock 240's back in or MAX 310's.
  3. IntegraB18LS
    shit, thanks man... well i havent put them in yet but my car is running super lean and stutering and stuff so i need to do something but I spent my last 50$ on the injectors untill i can find another job....
  4. pissedoffsol
    put the 240's back in, and DONT BOOST. have some control.
    running uber rich is not good for your motor
  5. Jim Truett
    Jim Truett Senior Member
    You need Uberdata. Check my sig.
    If you keep running lean you will melt a piston.
  6. Cashizslick
    FMU + DSM 450's = 6 miles per gallon highway.
    Try to pick up an AFC off Eghey for like 100$
  7. IntegraB18LS
    like i said i have not put them in yet, I guess ill have enough money in a month or so for a acf, hopfully can find one on ebay.....
    id rather run rich then hearing my car ping when i press the gas
