D deo Junior Member Sep 3, 2003 #1 Just wonding boys I had an engine swap in my 88 civic wagon....a ZC dual Cam running a 88 si ECU I was told that if I got an Acura 86-89 ECU I would just have to plug and play. Is this ok to do and if so can some tell me where I can find one? Later DEO
B blundar Senior Member Sep 4, 2003 #2 DO NOT use a 86-87 ECU. You need a 88-89 teg ECU. They look nearly identical. BEWARE the 86-87 ECU will NOT run your car. You can find them at a junkyard near you lol...
