..Um, there is A HUGE difference. FI cams have to stay within the operational parameters of the ECU makers designs. That's why you guys have to get the FI ecu's ' chip 're-burned' or reprogrammed in some electrical way.
BUT, in a carb'd engine, you have to remember that NOW that the motor is carb'd, the cam HAS TO be designed in a way to draw or suck the fuel (causing the atomization) instead of just opening up a valve for a spray or charge of fuel to be shot in the port/combustion chamber. (yes, I understand the FI motor still sucks air in)
ANYONE have any info on carb grinds for the B-series heads? Doesn't really matter if it's for the GSR or B-18, 20's.
Just wanted to use the crank girdle for strength, but it can change to the other B engines..
UNLESS there might be a way to 'trigger' the V-tech solenoid from a tach or linkage.
Thanks
