Dumb Question
Discussion in 'HYBRID -> EG-EK / DC' started by creepinRex, Feb 20, 2003.
  1. creepinRex
    creepinRex Member
    if i do a b16a sirII in my 90 crx si, will i still have a/c?
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Yes..you need a new ac bracket though (i think on the bracket part but yes)
    ...but dont get that engine, your wasting up to a thousand on that engine. Just buy a normal b16a SiRI, This engine came in crx's in japan. All you will need is new mounts and then wire it for vtec. With the b16asirII, you will need to get new mounts wire for vtec, use an older cable tranny or use a conversion plate to fit the sirII hydraulic tranny on your CABLE style chassis. Not to mention the b16aSiRI can be had for 1500 or less. The b16aSiRII will cost you at least 2200 then you have to do so much more other stuff. You would be wasting your money.
