dx out and z6 in....what do i need to complete
Discussion in 'Civic and CRX - EF' started by sasinorm01, Dec 13, 2007.
  1. sasinorm01
    sasinorm01 New Member
    i have a dx sedan and would like to put an z6 inside... i have every thing like z6 engine, L3 tranny, and p28 ecu...now what kind of wire harness do i need..
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you need the harness from the exact same car the motor and ecu came from..
  3. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    a z6 you say?? still a sohc so the dx wiring harness could be used..provoded you do the dpfi to mpfi conversion..id try and find an si harness
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if your car is a 93+just drop it in and run 2 wires and off you go, no need to swap the harness and if its a 92 no need to run any extra wires
  5. HATCHET_HONDA
    hobart, indiana
    yeah whut year dx is it?
  6. sasinorm01
    it is 89 dx sedan.....so what year and model harness
  7. AHHVTEC
    Alabama
    well i would still use the stock harness and convert to obd1 and mpfi, and you will also need to swap your stock driver side motor mount to the new motor
