DX STD w/ 4spd to 93 gsr db2 front disc swap
Discussion in 'HYBRID -> ED-EF / DA' started by JdmFr0g, Jan 22, 2006.
  1. JdmFr0g
    JdmFr0g Junior Member
    can i swap my 91 stock DX STD w/ 4spd to 93 gsr db2 front disc swap i have the whole front gsr suspension on hand i jus dont kno if 93 integ works on EF???
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    you can't just unbolt the knuckles and swap the GSR knuckles on unless you swap the hubs. The STD axles are smaller and splined differently than the GSR axles, and the GSR knuckles are taller.
    What you CAN do, however, is put the calipers, caliper brackets, and rotors from the GSR onto the DX hubs/knuckles, and it should work fine.
  3. JdmFr0g
    thats the thing im puttin the front disc in at the same time im puttin my b series in just waiting on mounts (on order(waiting))and since its a 91 dx std (4 speed)the integra axles wont fit (right)?..... so could i bolt all the integra brake caliper parts with the integra hub to the civic when u guys say use knuckles do u meen the ball joint .... a pic would help
    thanxxxx
  4. JdmFr0g
    bump for help PLZ! [​IMG]
  5. brian11to1
    brian11to1 Senior Member
    just so you know the 'db2' brakes are the same as all other 90-93 integras.
