no, you need nothing from the Si but the transmission. EVERYTHING from your DX will swap over. (axles, mount, linkage, reverse light wiring, clutch plate (assuming it's from the same year. the 88-89 disc has a smaller diameter input shaft than the 90-91. get a new clutch disc the same year as the Si transmission.)
