dx to vx
Discussion in 'Civic and del Sol - EG and EK' started by crxricer88, Feb 9, 2009.
  1. crxricer88
    crxricer88 New Member
    I have a civic hatchback dx that I took out the motor and plan on putting a vx in if not a d15b vtec. what things would i need? I still have the dx trans, so i believe that it should just mount right on, I know i need the ecu, anything else?
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    Alright... here is how it goes... U will want the Trany from the D16z6 or y8 or even a d15B trany because the shift points are difrent in the DX. You can use your stock harness in the DX tho you will need to run a wire from your vtec sylinoid to your ECU. The pin will be A4 . The next thing u will need to do is run a ground wire from the oil presure switch to the batary or ground it out on the chasie and run the other wire to the ECU to D6.... Below are the links to the ECU Have fun with the D15B if u get it and enjoy!
    http://www.dodo-upgrades.nl/pinoutp06p28p30_bestanden/image002.jpg
    PS u will need the p28 or p08 for vtec to work!
  3. spiritofjosh
    spiritofjosh know your role!
    ocean gate nj
    if you dont want to do that much wiring you can check rywire.com. they have the stock harness for si's there so you dont have to wire in the vtec, but if you get a d15b you're going to have to get a vtec oil pressure switch, theyre like 20 bucks on ebay if not cheaper. i think you might have to convert the o2 sensor to 4 wire too
  4. 99sidude
    Ohio
    the vx has a 5 wire o2.
  5. spiritofjosh
    ocean gate nj
    5 wire? im using a 4 wire now and it works fine.
  6. 99sidude
    Ohio
    If you use the vx ecu I'm pretty sure you're going to need a 5 wire o2.
