you are pushing a good bit of pressure 440cc injectors are good for 280flywheel hp if you go by hondatas specs
I have most of my timing taken out after 4K rpm thats why it stops making power
I have 440cc injectors and the shop I deal with will not push my car any more with out adding bigger injectors they say at the same boost "11PSI" with timing added it should be around 320-330WHP
I have a B16 with darton sleeves, JE pistons, Eagle rods.
its all in the tuning
if you want you can take your car to www.inlinepro.com they will get your car as it sits with the 370cc injectors to push 400+WHP
or you can do as I do.... and stay the F away from them halfassers
as far as B16s 300WHP is nothing for a boost B16
once he or better yet WE add bigger injectors we should see around 350-380WHP easy with the T3/T4 replace that turbo with a nicer one and 400-500WHP range is a pretty easy target its allll about the tuning
