Dyno Testing
Discussion in 'General Tech and Maintenance' started by BallinPrelude, Mar 6, 2003.
  1. BallinPrelude
    BallinPrelude Senior Member
    Wichita
    I was just wondering where can you get your car dyno tested at? How much does it cost roughly? And out of curiousity how do they actually test it? Thanks alot.
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    call around at performance shops, also i think if you go to the dynojet website they have a listing of people who use their dynos. it is not really dyno "testing" its more for "tuning" your car, ie: adjusting cam timing, ignition timing, fuel maps, fuel pressure, ... whatever else you have have that is tunable, to acheive a desired powerband.
  3. ekPhred
    ekPhred Senior Member
    roughly be willing to spend around $100 bucks an hour around here, i live in so cal btw. I hope that helps.
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    If you have the ablility use an engine dyno over the chasis dyno
  5. B16
    yay area, CA
    that would require pulling out the motor
  6. hcivic.com
    thats why i said if you have the ability
    most poeple i know build an engine outsida theie car so it is already pulled
  7. B16
    yay area, CA
    and most people tune the motors to get the best out at the wheels, because thats where the power really is.
  8. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    keep in mind unless your building an all out race motor that is going to be rebuilt rather soon slaping your 0 mile old motor to a dyno meter is well.... heres 3K bucks go burn it for me
    Jeff
  9. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    every dyno around here is 150/hr
    that includes wideband use and it is installed near your collector
  10. pills_PMD
    New Albany, OH
