E would be proud of me.
Discussion in 'Members' Lounge' started by jamesA, Apr 24, 2007.
  1. jamesA
    My rear brakes decided to start doing what they were doing two years ago. (remember that?)
    They aren't that bad, but they're getting to the point of no return.
    So I said fuck it and got some hawk HPS pads and brembo blanks.
    I may have to do the calipers as well. I'll get to learn how to bleed brakes.
  2. BodyDroppedNikes
    caught in a mosh...
    weeeeeeeeeeeeeeeeeeeeeeee!! this gonna be fun to do. i cant wait...
  3. jamesA
    at least this time I have my own garage though.
  4. E_SolSi
  5. Celerity
    Celerity Well-Known Member
    Bleeding brakes is SO easy.
    When you "bleed" a system, you're removing air bubbles. When the pedal goes down, fluid comes out. When the pedal goes up the piston goes the other way and sucks air in.
    Push the pedal down, allowing fluid to come out. Then seal it off, and bring the pedal up to fill the cylinder with new fluid instead of back-air. Repeat.
    Do this until the lines stops pushing out air bubbles (Little farts) and it's a continuous stream of brake fluid.
    That's the simple description. You'll want to use other methods (I use an air hose from the fishtank to examine the fluid for air)
  6. BodyDroppedNikes
    caught in a mosh...
    hell i will prolly have truck parts strewn all over the place as well.
  7. reckedracing
    reckedracing TTIWWOP VIP
    NY
    that works well too
    run the line into a small container with brake fluid so it sucks fluid instead of air
    the one person bleeders work well too
  8. pissedoffsol
    why do you need to do the calipers? are they frozen?
  9. BodyDroppedNikes
    caught in a mosh...
    we think one of the pistons in the caliber is stuck. its causing the brakes on the rear to squeel some kinda awful. not the squeel of brakes going bad but a squeel i have never heard of.
  10. Celerity
    Nope, One pad is just made of Butter.
    Here is yer sign.
  11. Celerity
    Also, now that I look at the picture, is that being balanced on your foot ?
    Your legs look like an H.R. Giger painting.
  12. pissedoffsol
    oh, i thought that was a before and after shot... not at the same time.
    so yeah, if one pad is getting killed, yeah, caliper is toast
  13. Airjockie
    Airjockie Watanabe Whore!!!
    Meriden, CT, USA
    squeelling is cause by the high vibrations of the pad riding on the caliper, thats why the grease is used as a lubricant to between the caliper and the pad.
  14. jamesA
    No, Steve, that was my old pad and the new pad which was replacing it before we put the new pad on in August 2005.
    The passenger rear pad wasn't down that far, that's the driver rear pad. It's the one squealing right now.
  15. Airjockie
    Meriden, CT, USA
    and just hone out the cylinder, scotchbright the piston, add a new o-ring...done.
  16. jamesA
    Aren't you 130 pounds as well? lol
    Edit: I'm holding the pads on the top of my right hand, my thumb is tucked under my palm.
  17. reikoshea
    Dallas, TX
    guns on the brain
  18. jamesA
    Autozone wants 57 plus a 44 dollar core charge for each front caliper, and 67 plus a 44 dollar core charge for the rear caliper.
    114+88= 202 and 134+88 = 226 = 424 bucks for calipers... of which I would get 176 back...
    Anyone know where I can buy rebuilt ones without a goddamn core charge? I don't feel like jacking up my credit cards anymore than they already are.
  19. Airjockie
    Meriden, CT, USA
    rebuild kits are like $5 each
  20. Airjockie
    Meriden, CT, USA
    take caliper off, use an air nozzal to pop the piston out, rip off all seals, dip into parts washer, dip into avgas, sandblast caliper, dip in avgas again, hone the cylinder, dip in avgas again, spraypaint, and then move to the piston. Wire brush it, parts washer, scotchbright pad it, dip in avgas, then open rebuild kit. dip seals in brakefluid, put seal on piston, put piston back in caliper, install piston dustseal, cavitate piston, and install on car.
    done.
