eagle hbeam rod question
Discussion in 'Engine Building' started by 90lst, Jan 23, 2009.
  1. 90lst
    90lst New Member
    Snow Hell, NC
    ok well i went out and got a set of eagle hbeams for my current build. i was under the impression from the people i talked to that they would work with the factory pistons. well when i took them to the shop, the guy told me he couldnt put them on the rods because of the bushing thats in them and that id need pistons that have the clips on either side of the pin. is there any way to get the honda pistons onto the eagle rods? any info is greatly appreciated, thanx guys.
  2. je power
    je power New Member
    my house
    ya you cant do that because the pin is pressed in and you need after market pistons with the rods. why would you wunna use the stock pistons anyway
  3. TurboMirage
    score a set of vitara pistons wicked cheap.
