Eagle Rods And Endyn Piston Problem..
tnsxsear
K i just finished putting my bottemend together with new everything, after i torqued everything down , i checked the clearances on the crank and its not tight enough. I have eagle rods and endyn rollerwave 12.5:1 pistons in a b18c5. Should i get the crank done 10 over around the rod journals and just use 10 over rod bearings? Ive heard alot of people have problems with the eagle rods in c5 motors. Thanx for the help.;.
-paul
