it would be the same, they are both direct bolt on's, just need to mess around wit the harness but its still a plug and play....I dont think of why te b18 would be harder than the b16 or vise virsa
the b18c will be a tad bit harder b/c of the intake manifold, but if you remove prior to throwing the engine in, youll be fine. Reattach once its in your car.
If the b16 is a direct bolt in why is it that on the sites reference page it says that you need the 99-00 civic si motor mounts and transmisson mounts??
if u plan on swaping any b seies into a 96-00 civic u WILL need the SI driver side motor mount bracket and the 99-00 SI rear L bracket so that the motor will align and sit right
