easiest way to get engine out
Discussion in 'Integra' started by hondamark, Sep 13, 2013.
  1. hondamark
    hondamark New Member
    I have a 96 Integra pulling motor. My question is does it come out the top or bottom.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Easiest if you have unlimited tools? Bottom.
  3. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    Pretty much you can take your pick. Personally, I have only pulled a b series out the top, using a cherry picker.
  4. eg6sir
    Easiest would be on a lift... support from underneath, unbolt/unplug everything, lift car, move motor out of the way
  5. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Lift is the answer. unbolt upper control arms and drop everything when you lift the car.
    But in the garage or driveway.....out the top. It's a bitch to bottom drop without a lift. I've done it and it was a scary joke.
  6. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    I always take 'em out the top with a cherry picker.
  7. eg6sir
    Majority of us do it that way... he asked for the easiest way though...lol
  8. Dual-500
    Fort Worth, Texas
    Easiest way is with a plasma cutter!!!! :)
  9. eg6sir
  10. E_SolSi
  11. Dual-500
    Fort Worth, Texas
    ^ ROFL That's awesome! I stand corrected, plasma cutter isn't the easiest method. This is clearly the easiest and quickest way!!! :)
  12. invisibledemon
    Tn
    you're all wrong.
    easiest way is out the bottom... with a cherry picker. (with our without lift)
    attach engine to hoist and lift enough for tension on chains. attach it level (after removing axles and disconnecting harness/hoses)
    release mounts
    put a small tire, or little engine dolly underneath and lower engine onto it.
    release engine from hoist
    if no lift is available:
    attach chain of hoist to the driver and passenger side mount with the mount bolt
    lift front end of the car enough to slide the engine out.
    if lift is available. just lift the car.
  13. CAFROG
    NOR-CAL
    I did this back in '98 when I removed my Z6. Lifting the car high enough to get the motor to slide out is what scared the hell out of me. I used wood blocks....sketchy. We had a heavy duty jack and it maxed out well before the car was high enough.
  14. invisibledemon
    Tn
    lol. thats why you use the engine hoist to pick the front end up.
    get the chain just the right length between the mount points and jack it up, i never put anything under the car, bc i put it up, pull out the block (usually have a chain or rope attached to pull the engine out so nobody has to go under the car while its up) and then drop the car right back down. the front end of a honda with no engine or tranny weighs nothing. hell, if you had two friends over, put one on each side and they could easily pick it up high enough to pull the engine out.
  15. Dual-500
    Fort Worth, Texas
    Car needs to be raised up to disconnect linkage, drain fluids, etc. Then set it back down to raise front end? I'm with CAFROG and set car up on stands, yank engine with CP and it's done.
  16. invisibledemon
    Tn
    i jack up the front, put on jack stands, and disconnect everything.
    engine hoist only comes into play when the only things connecting drive train to car is left and right mounts.
    lift with hoist, set back on stands.
  17. CAFROG
    NOR-CAL
    I get what you're saying now. Makes sense. But my old man back wouldn't like tugging the set up from underneath. I hate my back.
  18. Jeef
    Jeef NO MA'AM Moderator VIP
    I had a heavier friend of mine put his weight on the back bumper and that was able to lift the front enough to get the engine out.
  19. Dual-500
    Fort Worth, Texas
    ^ Was his name Jethro? Eustace?
