Easy question. D16y7 -> D16z6
Discussion in 'HYBRID -> EG-EK / DC' started by unsivil_audio, Mar 5, 2004.
  1. unsivil_audio
    unsivil_audio Ninja's pwn samuri's.
    Sheridan, Wyoming
    Okay guys my question is this, I have a 94 EX Sedan (d16z6) donor car that I'm going to be swapping into my 96 dx coupe (d16y7). I've noticed that when I pulled my motor out, that the OBDII engine harness was directly plugged into the ecu, but I cant remember where the interior harness comes into play (like it either plugs into that harness or if it also plugged into the ecu). My question to you guys is if I take the OBD I harness and use it in my OBDII car so I can just plug the P28 ECU directly into it will the (OBDII) interior harness plug in no problems (without hacking, or should I just hack the plug off the other car and transplant it on my car)?
    Thankx in advance
    Joel
