Ebay Special- Short Shifters
Discussion in 'Body / Exterior / Interior / Cosmetics' started by Andrew, Mar 6, 2006.
  1. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    I have a 1991 CRX Si, thats about to get a b16a1, and I was just wondering if those $15 short throw shifters from Ebay are beneficial at all?
    Does the actual shift 'throw' shorten a bit?
    Is it bad for the the tranny in any way?
    Thanks
    -Andrew
  2. E_SolSi
    they are cheaply made with shitty material and they brake
    fuck those things
  3. formby
    formby learning in progress
  4. eg6sir
    i've had a couple of them.. one on my old car and one on my current car.. i've had no problems with them... yes it did shorten my shift, but if its more than the namebrand ones.. i dont know, i've never had one...
  5. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    If you're on the cheap, try cutting down your stock shifter a bit. Don't go balls wild like some ricers do, so that the knob is in the boot - though. I did it on mine, and I love it - especially with the ES bushings.
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    If you're actually looking to reduce throw without sacrificing height, take the stock rod to a shop and have them extend the bottom part.
  7. Andrew
    Tallahassee, FL
    I'm not on a budget, but was just curious.
    Obviously a name-brand one will perform better and be made of better materials(and hate me all you want, but I don't believe you when you say you broke it in half. If you did, LAY OFF THE STEROIDS =))
    I might pick one up and give it a shot.
    If I don't like it, and I see a problem, I'll just pick up a nice one, or just go back to a stock one.
    Thanks fellas
    -Andrew
  8. 92civicb18b1
    92civicb18b1 The Trisexual
    I used to beat the living shit out of my shifter...never had a problem.
    I actually bought one for the Audi because I hated the push down reverse and the throws were kinda long. I beat the living shit out of this shiter too and no problems yet.
  9. friz
    friz Senior Member
    OZ
    I got a B&M for 45. I thought that was pretty cheep.
  10. Andrew
    Tallahassee, FL
    How do you like it?
    Have you used crapy Ebay ones to compare it(shift throw)?
  11. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    My ebay special broke while it was in the shop getting new tires put on, so they payed me for a replacement OEM shifter which I prompltly returned for a $100 rebate on my tires :) !!
  12. Andrew
    Tallahassee, FL
    How the hell did they manage that? [​IMG]
    How was the feel of the shifter when it was good??
  13. K2e2vin
    Raleigh, NC
    I have the cheaper B&M w/ ES bushings and a Neuspeed in my current car; IMO Neuspeed>B&M. The more expensive B&M *should* be better though.
  14. Andrew
    Tallahassee, FL
    think neuspeeds are in the $40-70 range? jsut guessing.
    And would changing the bushing on a Hasport linkage be beneficial for smoothness, or are they pretty much top-notch?
  15. ScrapinSi
    ScrapinSi Senior Member
    I had an el cheapo ebay shifter... didn't really have any problems with it...
    Another thing to CORRECTLY make your own short shifter is to cut about 1" below the ball, and about 1.75" Above the ball, flip it, and reweld it...
  16. hosmer
    B R I D G E W A T E R
    Mine (cheap Ebay) rattles on my exhaust (RSR Exmag)...its really fucking annoying
  17. Andrew
    Tallahassee, FL
    huh.
    It sounds like some people never have a problem and some just break em in half(ha).
    I'll go ahead and pick one up. for $10 its worth a try...
  18. integragsrr
    integragsrr Junior Member
    I had one break on me too...now i just use the stock one.
