KloggMonkey
Member
I have checked the plugs on the injectors the ground wires all are grounded .....
I have checked for continuity from the A plug on the ecu to the wires on the injectors and They are fine......(plug A pins 1-4)
I unhooked an injector plug and hooked the wires to a mulitmeter to check the voltage when I turn it over there is none~!!!!!
I have good ground to them all and the 4 other wires that go to the ecu from the injectors have continuity....
So the ecu must be not sending the signal to the injectors ..... could that be the immobilizer thing....????
Any ideas.... or suggestions would help me out ......
would my ecu from my CX work as a test ecu.... (P2E i believe)?
