ecu and o2 sensor question
Discussion in 'ECU's, Electronics, and Tuning' started by erebunicrx, Jun 14, 2004.
  1. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    i swapped a ls into my 91 crx si. i used the stock ecu. but schould i get the 91 teg ecu? how much power am i losing? also when driveing for a while the cel comes on and says the o2 sensor is bad then i shut the car off for a second and the light goes off and car runs fine after.
  2. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    either chip your stock ECU or use the teg ECU. nothing else to be said.
  3. erebunicrx
    Bristol ct
    ok so am i losing power with the stock ecu? or am i losing just the higher rev limiter. thanks
  4. pissedoffsol
    the fuel maps are all wrong.
    get the teg ecu.
    it may solve your o2 problem as well- due to it giving it the wrong fuel and making it run improperly
  5. erebunicrx
    Bristol ct
    ok thanks, got one for sale? :p
  6. pissedoffsol
  7. radnulb
    Sinsinnaty, Ohio
    I have a PR4 sitting around. PM me.
