ecu and wiring question for b18a swap into 95 civic
labe lincoln
Im droping in a 93 b18a into my 95 civic. I just need help on knowing what all I need as far as computer and wiring harnes goes. This is my first swap. I need answeres. Also any other things you believe i will need for the wiring.
The wire harness from the civic will fit on the b18a. Youll need a 5spd 92-93 obd1 pr4 or a 5spd 94-95 p75 ecu. You could also chip your current ecu and run the b18 program on it.
Dont forget youd need engine mounts from a 94-up integra
Good luck
