ECU CEL
Discussion in 'HYBRID -> ED-EF / DA' started by VTECPOWER, Jun 19, 2005.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    I need to know what these cel's are, the led light on the ecu blinks 2 long times then 4 short, also once I know which codes these are throwing i need to know how to fix them, engine is a b16a1 w/ a pw0 ecu and rywire engine harness, car starts idle's kinda rough.
  2. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    24? HUH?
    Maybe The ICM(ignition Control Module)... :unsure:
  3. VTECPOWER
    Winchester, VA
    yeah i know, 24???? i thought that code didnt exist but it does blink twice for a long time, then 4 quick, i think ill call rywire tomarrow see if they can help. since i got the harness from them.
    Anyone have any other ideas?
  4. Estorvito
    Orlando FL
    Try another ECU.....
  5. VTECPOWER
    Winchester, VA
    Easier said than done, all i have is my crx dx ecu, and a obd2a civic ex ecu.
  6. VTECPOWER
    Winchester, VA
    Um....... yeah, so anyone got any ideas? like i said blinks 2 times long duration then 4 short, car does not go into vtec, i need to find out these codes and fix them.
  7. ripperbone
    ripperbone angry bear
    Oklahoma
    are you sure its 4 short blinks, cause I looked at my code list and didnt find a code 24.
    is there a pause in between the 2 long blinks and the 4 short blinks?
  8. VTECPOWER
    Winchester, VA
    yes, pause between the two long blinks also, so im not sure what it is.
  9. Estorvito
    Orlando FL
    wow.. THe only thing i can think of is the ECU man...
    I've asked a couple of guys here local and they have never heard of a 24 code.
    I dunno.....
    But Good luck though....
  10. VTECPOWER
    Winchester, VA
    Is there any way that the 2 long blinks are just like a sensor warning light or something? and then it being a code 4?
    I bought everything from hmo, should i just give them a call and ask for a new ecu?
  11. jdm2gen03
    jdm2gen03 Senior Member
    could be a 10 code then a 14 code, jus my thought...... cuz i threw a 9 code then it puased and one long blink and 4 short for a 14 then pause 2 long blinks then pause an d 2 more long blinks and 2 short. so u might wanna check that.
    all in all i threw 9-14-20-22
  12. VTECPOWER
    Winchester, VA
    thats what i was thinking, maybe 2 codes as in a 10 and a 14, which are 10 = IAT Sensor (Intake Air Temperature) and 14 = IAC Valve (Idle Air Control).
  13. VTECPOWER
    Winchester, VA
    Would those codes effect vtec? i tried do "hit" vtec and it did not engage, i was up to temp, and i hooked up an oil pressure gauge and it read about 70psi when on the gas completely, sometimes the oil pressure is at about 40+ psi at idle. Which is high correct?
  14. jdm2gen03
    i think code 10 might not let u hit vtec.. i'm throwing code 14 and still hit vtec so u should look at gettin those fixed , most likely just faulty wiring.
  15. VTECPOWER
    Winchester, VA
    the car is in limp mode and rev limiter is at about 7500 rpm, wiring was rywire, so i guess ill keep trying to contact them.
  16. ripperbone
    Oklahoma
    anytime your car goes into limp mode, vtec will not work.
    if your having a problem getting a hold of the guys at rywire go to their forum at www.norcalcrx.org they always check the forum at least once a day
  17. jdm2gen03
    yep limp mode will not allow vtec crossover. its weird i'm at the moment throwing 4 codes and the car still isnt in limp mode. but most of the codes i'm throwin involve wiring with my pigtail. so that prolly y.
  18. 90b16acivic
    90b16acivic Junior Member
    if you dont mind me asking what is limp mode?
  19. VTECPOWER
    Winchester, VA
    engine doesnt rev as high, vtec doesnt work. because of cel's
  20. jdm2gen03
    limp mode is when the ecu sees a cel that could harm the engine so it lowers the red line and richens up the a/f ratio and makes some things not work like vtec.
