Ecu "clicking" then burned Help!!!!
Discussion in 'ECU's, Electronics, and Tuning' started by Blakakura, Jan 10, 2006.
  1. Blakakura
    Blakakura Junior Member
    H22a swap in a 97 civic. I put the ecu in and turned the key and all i got was a "click". So i thought mabey the battery was just low. Grabbed some jumper cables and tried again. All i got a was a click from the starter and an even louder click from the ecu. Engine didnt turn at all. Then i get the wonderfull smell of something burning, pulled the cover of the ecu and it was all burnt up. Any ideas of what went wrong?
  2. reikoshea
    Dallas, TX
    Is it an OBD1 H22?
    Im willing to bet you jumped a perfectly good battery and didnt have your ignition coded for the immobolizer.
  3. pissedoffsol
    where was the click coming from?? the main relay area (under your steering wheel) or under the hood?
  4. Blakakura
    It sounded to be under the dash somewhere, its converted obd1 with a jumper harness and p13 if that helps.
  5. reikoshea
    Dallas, TX
    hmmm, clicking under the dash = main relay me thinks.
  6. TeamUrbanChaos
    TeamUrbanChaos Certified H22 Super-tech
    Home Of ThE LoSt Towers
    i had the same problem a couple of weeks ago man.....my battery was dead and i tried to to start my car off of the little bit of energy in the battery and wound up burning up my starter motor. the clicking noise your hearing is one of the relays under the dash either the main fuel relay or one of the 3 fuse relay on the bottom fuse cluster under the dash. all in all....make sure u dont try to start you car when u hear the clicking. i learned the hard way and tried to start it off of like 5% battery life. it cranked for about 2 seconds and then began to make a repeated clicking noise and the my starter made a wierd noise and never worked again
  7. xenocron
    xenocron Member
    Bergen Co., NJ
    What part of the ECU was burnt up?
  8. HybridEk
    HybridEk Junior Member
    Sorry, ive been trying to login for a week or so and it wont, so i reged a new account. Anyways heres a pic of what burned.
  9. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    Weird, that sucks...I have had the main relay go crazy and freak me out when I switched bins with the engine running, but thank god I never burned anything up. that sucks.
