ECU Code 13???
fixed4 life
Just got a 91 teg and the ecu is throwing a code Flasssssssssh then flash flash flash im guessing that is a code 13 Atmospheric Pressure Sensor - Defective circuit or unplugged/ Defective sensor where is that located also it idles at 3000-4000 rpm's any body have some info on this
Get a factory service manual it should have pics of every location of every electrical plug on the car under the hood. It might be a specific electrical troubleshooting manual.
idle could be a vacuum leak. My integra did the same thing, check the hose going to the plenum of the intake manifold.
