ecu code 6 help
Discussion in 'ECU's, Electronics, and Tuning' started by smooth95, Oct 22, 2005.
  1. smooth95
    smooth95 Senior Member
    South Cali
    hey Im having a problem im throwing a code 6 I replaced the thermostat and the ect sensor whats my next step its still a code 6
  2. eg6sir
    check the wiring...
  3. reikoshea
    Dallas, TX
    You replaced the sensor on the back of the block, right? Not the one on the coolant return line.
  4. smooth95
    South Cali
    I replaced the one right under the distributer
  5. reikoshea
    Dallas, TX
    which plug...try to get me a location if you can see it in this pic...
    If you replaced the green plug near the dizzy...thats the fan switch (i should know...my fans dont kick on because my exhaust manifold burned throught the wires)
    The ECT is on the back of the block by above the oil filter (if memory serves...my manual is at the shop with my car)
  6. smooth95
    South Cali
    thats an h22 on a b18 it is right there but in the back of the block next to the thermostat should I replace the ect switch also, could that be why my fan aint kicking in and throwing a code 6.
  7. reikoshea
    Dallas, TX
    oh, i saw H22 in the sig, so i assumed thats what you were working on.
  8. smooth95
    South Cali
    oh sorry about that i have an h22 in my accord right now im working with my b18 civic thanks
