ECU confusion..
Discussion in 'ECU's, Electronics, and Tuning' started by dirt817, Jul 19, 2004.
  1. dirt817
    dirt817 Member
    Pittsburgh
    I've been bored lately and reading about ecus. I've discovered that there is a difference between the 88-89 pm6 and 90-91 pm6 (the ecu i'm currently using). I have an 89 crx hf with a 91 d16a6 running the stock pm8. I bought a 91 pm6. The ecu doesn't work properly and its either a bad ecu, or something is not compatible.
    Several websites say the 88-89 pm6 does not have an external eprom and the 90-91 does. Would this make any of the internals different and cause the ecu to have different pinouts?
    This is mearly out of curiosity as I'm dropping a z6 in the car eventually and its not a daily driver, I bought it for a build-up.
  2. ohmstable
    ohmstable Senior Member
    Toronto, Canada
    Thats right, 88-89 pm6 don't have external roms but 90-91 pm6 do. However the pinouts are identical.
  3. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    They both work, right? If not, what is the diff.?
  4. hybrid89
    hybrid89 thistownsucks...
    SoCal
    88-89 non removable e prom
    90-91 removable e prom
    intentical fuel/timing maps
