ecu for g series project
Discussion in 'Accord' started by need2bfaster, May 13, 2009.
  1. need2bfaster
    need2bfaster New Member
    pa
    what ecu would i need for the g series build h22 on a 90 -93 accord its obd1 non vtec can i use a 94 civic vtec or 94 accord vtec ecu and does any one happen to know what the compression might end up being after the head swap im trying to get an idea if i can still get away with stock internals on 6 psi
  2. BrutalB83
    Rochester Hills, MI
    If you insist on using a stock ECU, then using the ECU that goes with the head you're using is probably the best bet. Ideally though, you'll want to get an ECU chipped and custom-tuned to your build...
  3. need2bfaster
    pa
    i am curently boosted i have a chipped ecu (po6) which is already tuned for my set up but its a non vtec ecu i know to use a vtec ecu but if i cant find the ecu that goes with the head is there an atlernative ecu i can use to get chipped
  4. BrutalB83
    Rochester Hills, MI
    P28 (92-95 Civic Ex/Si)
  5. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    What's a g series? V6?
  6. spacemanspiff
    spacemanspiff New Member
    outside philly
    f series with an h series head its between f and h which is g.
  7. efhondakid
    Akron-Canton, Ohio
    With K series pistons.
  8. need2bfaster
    pa
    arent the k series pistons used for n/a motors not boost
  9. laprise1990
    laprise1990 New Member
    how do i post a thread
  10. need2bfaster
    pa
  11. efhondakid
    Akron-Canton, Ohio
    All the G builds I have seen are nasty N/A motors, they are the cheaper alternative to going K.
  12. need2bfaster
    pa
