ECU for K20A
Discussion in 'ECU's, Electronics, and Tuning' started by rcaca0, Jul 1, 2013.
  1. rcaca0
    rcaca0 New Member
    I was reading that there are two different ECUs for the K20A engine: PRD and PRC. One is for a civic and the other for a RSX. Besides the cars, is there any difference between the two ECUs? Are they interchangeable?
    Thanks,
    R
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the maps will be different.
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Civic Type R (PRD)
    RSX Type R (PRC)
    Yes....interchangeable.
    Work of mouth is the PRC has a more aggressive map. No first hand knowledge of the PRD but I ran a PRC for a while.
    Also....some of them need a Imm Bypass unit for a swap. Mine did. Which means they might not work without the correct key in non swapped cars.
  4. rcaca0
    rcaca0 New Member
    What is a IMM Bypass?
    Thanks
  5. rcaca0
    rcaca0 New Member
    Also dumb question, if I am flashing the ECU with Hondata PRO, does it matter if it's a PRD or PRC?
    Thanks again
  6. phunky.buddha
    Dallas / Fort Worth, TX
    Immobilizer maybe?
    Probably not- talk to your Hondata vendor.
  7. CAFROG
    NOR-CAL
    Sorry. Immobilizer Bypass Unit.
    In terms of Hondata K-Pro....they won't be any different. Both have reverse lockout (6-speed thing) and will accept K-Pro just fine. They are both JDM ECU's. Sadly....they will not have nitrous tuning abilities that USDM ECU's do. Not to say you are unable to run nitrous....but you won't be able to tune it nearly as well as a USDM ECU (in terms of Nitrous ONLY).
  8. CAFROG
    NOR-CAL
    Also....no Immobilizer Bypass Unit is needed if you run K-Pro.
