Ecu help please
Discussion in 'ECU's, Electronics, and Tuning' started by CRXLS/Vtec, Sep 12, 2008.
  1. CRXLS/Vtec
    CRXLS/Vtec New Member
    NH
    I bought someone elses project and after reading on the forums i'm confused. I have a JDM b16a with out the Pr3 ecu. I recieved a P72 ecu from a gsr. This is all going in to a 91 crx si. Is this going to work? Did i get screwed? What do i do? If i buy a obd0 to obd1 harness will i be ok?
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i would run the pr3.because its for the motor...sell the p72 and dont worry about buying the jumper harness,,,why would you want to run the p72 anyway?
  3. CRXLS/Vtec
    NH
    it came with the motor......will it work?
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    sure itll work,but as i said just use the pr3..that way you dont have to spend money.you can save money
  5. CRXLS/Vtec
    NH
    don't have a pr3......
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    oooh my bad..sell the p72 and buy a pr3
