Ecu help!!!
Discussion in 'Civic and del Sol - EG and EK' started by importfancy, Feb 6, 2011.
  1. importfancy
    importfancy New Member
    Del Sol d16y8, was throwing CEL: EGR valve, that motor does not have one so I was told to buy a p2p ecu. I did this but the plugs do not fit in to the new ecu. The ecu in it before was a p24... What do I do about this?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the del sol came with a obd2 p28, that ecu is what you need. also keep in mind with civic ecu like the one that didnt work for you comes obd2a and obd2b the plugs are different between the years
