hybrid99hatch
Allright Im pulling an already swapped motor and re swapping it into another civic hatchback. The motor is a del sol B16a3 and it is in a wrecked 96 hatch, I need to drop it into a 99 hatch. Sounds simple but Im having difficulty with the the ecu wiring. I wanted to try disconnecting the already wired up ecu through plugs. without having to cut wires. Disconnect and connect would be cake. I cant find out where to disconnect corrrectly. Every time I think I have found the easy route The wire spiderwebs 20 feet under the dash. I need help. Where can I find the right wiring diagram if I need to start cutting. also is ther an easier way to approach this or am I making way too much work for myself
