Hi,
You guys seem to be the most knowlegeable on teh web so I am hoping you can help.
I like in the UK and have a Mini. I have put a Honda CIVIC B16A2 (DOHC) engine into this little car and now have to do the wireing. I have heard that I have to have the matched key, immobiliser and ECU to get the car to run propperly - firstly is this true?
Running on this theory I went out and got the wiring from a 1997 SOHC Civic. It had the same generation ECU (OBD2) however when I got it home the ECU's are different - the DOHC one is a PT2 but the SOHC one is PTE. DOES THIS MATTER and if it does can I simply plug the PT2 one into the harness i.e will this ECU run with the immobiliser and key from the other cars wiring.
I hope that made sense cos I am really stuck at the moment.
Thankyou
Paul
Thankyou
Paul
