ECU PROBLEM with check engine light
crxturbo9psi
I have a b16 with a pr3 ecu and I'm getting a code thrown at me its 6 long flashes and 8 short flashes! what would that be? And the car spudders at like 5500 rpm. Maybe a bad o2 sensor? Im not sure someone help please
Id say o2 or egr.
and after looking up the code...code 67 is all i can find that is close. And a bad cat (code 67) could also cause that problem.
i came up with a couple possible combinations with that code..
10 & 58
IAT...TDC sensor... but thats unlikly because its only on a V6
or
20 & 48
Electrical load detector.....Lean Air Fuel sensor (LAF)
EGR is usually between the fuel rail and the IM. got a vacuum line that usually runs right on top of the fuel rail.
