Ecu Problem?
Discussion in 'ECU's, Electronics, and Tuning' started by D See 2, Feb 22, 2003.
  1. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i've been having an electrical problem for the last few months. maybe you guys can help out...
    what does it mean if the check engine light on the ecu is solid on. not blinking at all and my motor wont rev past 3K?
    (pr3 obd0 so i dont have to jump it or anything)
    i shut the car off and back on and its fine again.
    then randomly it will do it again and not let me rev past 3K again...
    sometimes it will do it right away and sometimes it wont do it for a few mins.
    it all started when i installed a fuel pressure regulator and it was in the way of the IAT sensor and i let those two wires touch together.
    could something like that short out an ecu?
    thanks.
  2. D See 2
    Baltimore, MD
    no one has had this problem before.
  3. Havok
    Havok Senior Member
    Florida
    I don't think those 2 things should affect an ecu whatsover, I've never heard of this problem. Saturdays are crappy days here, there are like 4 posts a hour, wait until late tonight, or tomorrow, I'm sure someone will be of help.
  4. D See 2
    Baltimore, MD
  5. D See 2
    Baltimore, MD
    pipe and a crepe non?
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    blunt and a pancake?
  7. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Sounds like a bad ecu connection.
  8. xj0hnx
    C.C.TX.
    Sounds like it is going in and out of safe mode.
  9. pissedoffsol
    sounds like you might need to go to the *cringe* dealership and have them put it on the scan tool
  10. D See 2
    Baltimore, MD
    ecu's have safe modes?... what can cause an ecu to go into such mode?
  11. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    honda engineers put a "safe mode" on all their ECU's .. when many systems fail, they go into a safe mode, which runs only the most necessary sensors to keep the vehicle running so you can get it into a repair shop...
    i would have it scanned at a dealership or other jap repair shop
  12. pissedoffsol
    read the FAQ y0! i made a post in there about the 2 modes of the ecu
