ECU Problem
Discussion in 'HYBRID -> ED-EF / DA' started by E.N.G, Oct 23, 2007.
  1. E.N.G
    E.N.G New Member
    Hello, I just put in a zc engine into my 89 crx, i have all the wiring harness and obd0 to obd1 jumper harness. I got my buddy to get me a p28 computer for the car but he send me a obd2 p75 computer. Can some one tell me what is another computer i can use. The vtec will be ran through a vtec controller.
    Thanks
  2. ch1nky
    ch1nky New Member
    is it sohc or dohc? i have a dohc zc obd1 and im using a p06 from a civic.
  3. Hasid Lafre
    Hasid Lafre Master of the obvious
    There is no vtec dohc zc motor to my knolage.
  4. BrutalB83
    Rochester Hills, MI
    I don't think he said his DOHC ZC had "vtech," did he?
    It's "vtec" by the way.
    As for the original question, unless you need the car running right now I'd just keep looking for another P28. My preference would always be to use an appropriate ECU to control VTEC, rather than some kind of piggyback device.
  5. Hasid Lafre
    meh its a habbit for me to spell how it sounds.
    I never heard of a vtec dohc zc
  6. BrutalB83
    Rochester Hills, MI
    You're right, there isn't a VTEC DOHC ZC. That's what I'm saying, ch1nky's comment was completely irrelevant and off-topic. The OP is asking which ECU he needs for his single-cam VTEC ZC, and then the other guy made some comment about running a P06 on his dual-cam ZC.
    As for spelling VTEC, just keep in mind that it's not referring to "tech," like "high-tech," but rather it's an acronym; each letter stands for something.
  7. ch1nky
    ch1nky New Member
    well if you know that there is no dohc zc vtec then im just letting him know which ecu to use that wud work on a obd1 dohc zc
  8. Hasid Lafre
    And even then Ive never heard of a sohc vtec zc.
  9. norcalgsr
    NorCal
    Well there is one so maybe you should do some research!
  10. Hasid Lafre
    Unless the honda/acura motor list on this site is outdated I dont see a sohc vtec ZC motor.
  11. BrutalB83
    Rochester Hills, MI
    Yeah it's not on there. The ZC motors are just an offshoot of the D-Series, so the single-cam VTEC ZC is pretty much just a D16Z6.
  12. Hasid Lafre
    Then its not a ZC, its a d16z6. Unless I see a block stamp of a sohc vtec stampted ZC then to me there is no sohc vtec zc.
  13. jlicrx
    jlicrx Senior Member
    Colorado Springs
    this is a SOHC VTEC ZC (valve cover from factory is black) - all SOHC VTEC ZCs have serial number starting with '7' - we have swapped several of them
  14. Hasid Lafre
    Ok then. Could someone maybe be so kind as to update the motor list so others dont get confused.
  15. jlicrx
    Colorado Springs
  16. Hasid Lafre
  17. BrutalB83
    Rochester Hills, MI
    Yeah, thanks for not believing me...jackass...
