ecu problems any help
Discussion in 'ECU's, Electronics, and Tuning' started by crazyboy2431, Apr 10, 2008.
  1. crazyboy2431
    crazyboy2431 New Member
    I have a 1990 crx with a b18 b1 what ecu do i need to make it run
  2. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    dont double post. have a mod delete or lock one of these.
    your not giving enough info. do a little research. that's why we have a reference and tech article section. not to mention the search function.
    there are 2 types of B18B1. hopefully your talking about the OBD1 version. that's out of a 94-95 integra. the factory paired ecu is a P74. all that info is from our reference materials. you could get one of a handful of other types of ecus and get a chip programed for it that has the B18B1 maps, but it would probably end up costing more.
    ...last time i'm giving you easy answers. search a little, and make your question detailed. if you cant find it, atleast say you've tried.
  3. BrutalB83
    Rochester Hills, MI
    Is this question really that difficult? Have you considered trying the one that originally came with the motor? I guess that would make too much sense...
