88crx type r
now i've been told a OBD2 can not be chipped. Is this true? 2. l have a 88 crx and i'm dropping a b18c5 OBD2. My crx is OBD0. I was told to go with OBD2 to OBD1 to get the most rpm out of the motor and it would be less problems the OBD0. Also do i use the wiring harness from my 88 crx si or from the 99 b18c5 motor?. I have yonaka motor mounts and the front clip of a 94 integra. will the axles work and shift linkage? If anyoe has any info it would be great
