ECU short/wiring fail, hell idk..
Discussion in 'General Tech and Maintenance' started by Matts96HB, Oct 14, 2008.
  1. Matts96HB
    Matts96HB . Moderator VIP
    As most of you know, I'm doing some work on my 96 Hatch. LS, OBD2>OBD1 conversion harness, chipped obd1 p75 ecu. EX cluster, everything else is stock.
    Got the battery in and figured I'd try all the electrical stuff I did, and it didn't go so well.
    Problem:
    When I turn on the headlight switch, the ECU makes this wierd and LOUD clicking noise, and the dash lights flicker. Also, the blinkers are working at abnormal/inconsistent intervals. I am going to post a video of the problems I am describing here in a second.
    ANY help with this would be greatly appreciated, I just need suggestions because I am lost at the moment, I can't think, I don't know where to begin.
    Thanks all
    Vid coming in a sec.
  2. Matts96HB
    Also, head unit will not power on. AT ALL.
    The speedometer also jumped up erratically just a second ago. Not sure wtf is going on :(
  3. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    I have heard that if your power is flickering while the car is running and the head unit is also acting up its your alternator going bad. Thats all i know. Do things run right with only the battery on?
  4. Matts96HB
    The car isn't running.
    Its just battery. So this is with the ignition just in the ACC position.
  5. |Chaz|
    |Chaz| Well-Known Member VIP
    Weird man that sucks :( , I hope you get it figured out soon.
  6. Matts96HB
    Thanks man, I got so frustrated tonight that I just put the tools down and walked out of the shop, closed up, and hit the casino.
    Won $260 at the blackjack table so that helped my cause, but this still is eating at me.
    Checking fuses tomorrow, then I'll look into the wiring.
  7. efhondakid
    Akron-Canton, Ohio
    My friend had a similar problem with his Teg. He converted to OBDI and put in a JDM ITR cluster. After he got it all in/done he turned it to the ACC postion and had the same or close to the same symptons you have. I forget what the problem ended up being, Ill ask him. Do you have all your grounds hooked up? And you did a wire tuck too didnt you, that sucks man, best of luck, hope you get it all sorted out. :thumbsup:
  8. Matts96HB
    Yes, and thank god it was only a headlight harness tuck for the most part.
    I'd be interested to see what it turned out to be for your buddy. Let me know man. Thanks :)
  9. Matts96HB
    Ready to see my fail?
    Here you go all, let me know what you think.
    Meh.
  10. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    damn thats like nothing i've ever sees... you need guru :eek:
  11. Matts96HB
    Yeah man no joke.
    Well I pulled the ECU and popped my OBD2 ECU in, and its still doing the same thing. So its not the ECU. However, I did notice something with my fuel pump cutoff switch, however not sure if this is any part of the problem with the way things have been acting..
    When I shut the pump off, no noise doesn't occur.
    When I turn the pump on, noise occurs.
    Not a whole lot I can do right now anyway, I don't have power anymore lol I popped a fuse somewhere else.. JESUS christ anyone wanna buy a hatch? lol
  12. |Chaz|
    Haha man you'll figure it out. Just be patient, you'll get it. Double and triple check everything and then check it again. I'm sure you'll find something.
  13. |Chaz|
    Wowza. I just watched the videos, that is so amazingly weird.
  14. INJEN78
    INJEN78 HS LEGEND
    OHIO
    its like theres a really bad short somewhere..what wires did you mess with??
    just the headlight wires?
  15. Matts96HB
    Yeah just headlight wires. Popped a fuse somewhere tonight, no power anywhere. Hopefully I didn't fry the ECU. =/
    Cannot be the headlight harness at this point. I unhooked it completely. Still getting the same shit. I have no idea what the problem is.
  16. awptickes
    MD
    Have you checked every single ground on the whole car?
    1 person likes this.
  17. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    wow.. that growling is horrible! is this just when u turn the lights on? my stereo in my ef would cut off when i switched the lights on. it was the alternator and the battery had a low charge. enuff to start the car up but not enuff to power everything at once so turn one thing on the other cut off....it sucked
  18. HATCHET_HONDA
    hobart, indiana
    aaand it made a cracklin sound and the turn signals flashed all fucked up'ish
  19. INJEN78
    INJEN78 HS LEGEND
    OHIO
    maybe you got a fucked up conversion harness?
  20. Matts96HB
    You know what, I have not. I checked the ones in the engine bay last night, and they need some work. I COMPLETELY spaced the fact that I had painted the bay, and that there might be paint in some of the threads, which = shitty ground.
    +1 to your thought as well, I never thought about it, but the battery IS on a charger, but that might not be enough to keep the charge up. I need a new battery anyway, so it sounds like thats on the to do list.
    I'm guessing that could be my problem then. Im going to try the battery first, and pray that I didnt murder anything
    Thats a possibility, I'm thinking thats not too probable though, we'll see what happens. Its always the simple stuff lol
